Go Back  Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
Rex Marine Superstrainer™ Sea Strainers >
Rex Marine Superstrainer? Sea Strainers
Old 09-09-2008 | 04:49 AM
rexone's Avatar
Default Rex Marine Superstrainer™ Sea Strainers
Link to actual website page
The new strainer Wrench... No more hassling with crescent wrenches, big steel wrenches, or channel locks getting the top off.
Below is close up of the lock pin mechanism "disengaged"...
Below is close up of the lock pin mechanism "engaged". The pin is designed as a safeguard to prevent the top from unscrewing from vibration and pounding these boats experience...
Below is pic of a complete Blue Strainer unit. Strainers come standard with a 1" NPT port in, a 1" NPT port out, and a 3/4" NPT port for pressure bypass valve line or other requirement. Additional fittings can be added via special order if you have special needs for more fittings. This takes a little time though as we pre-build the body assemblies with the fittings welded on for the most part. The can and fittings and the top nut are all 316 Stainless.
rexone is offline
rexone's Avatar
Below is a photo on the underside of the aluminum top. Notice the series of holes around the perimeter. These are the holes that the lock pin registers in to insure the top does not come unscrewed in use. Also "Rex" is engraved here and on the new investment cast cans, in the bottom of the can. You can easily identify a genuine Rex Superstrainer™ from an inferior made cheap knock off... If it doesn't say "Rex", it's not a Superstrainer™ nor is it built with the quality and attention to detail we employ... I mention this only because we've had an issue with a competitor attempting to copy the product.
rexone is offline
Mackattack
11-20-2007 12:07 PM
RedDog382
05-17-2007 11:01 AM
Dusty Times
3
04-09-2004 11:01 AM
LubeJobs42
03-16-2003 07:00 PM
Daryl
Fountain
2
11-12-2002 02:27 PM
