Water Pickups
Just curious to thoughts about the Formula water pickups on the boat. I will be working on the transom and repainting the drives. Should I consider a diferent pickup on the boat or is it not worth the hassle...what pickups should I consider if replacing?
We have found that the best results for cat's have been from thru-hull pickups rather than a "ram horn" or transom style pickup. This has been most recently documented in one of many series of articles on the buildup of a 27' Eliminator Daytona by yours truly, CP Performance. May 2008 issue to be exact, in which installation of the pickup is reviewed. The pickups are adjustable and can be viewed here at the bottom of the page. I can also provide pictures of the install if needed. Let me know if you have any further questions and thank you!
