Brass, copper fittings in Stainless strainers? >
Old 09-09-2008 | 04:10 PM
Default Brass, copper fittings in Stainless strainers?
Is it OK to use brass or copper fittings in a stainless sea strainer? Any dissimilar metal issues?
I have a tough tiime finding stainless, 1 1/4 NPT thread to water/hose barb pipe fittings.
PARADOX is offline
Old 09-09-2008 | 04:19 PM
Registered User
Brass is the gold standard for breaking the dissimilar metals chain. That's what you use on connections between steel & copper. But you're going to rubber anyway so it doesn't matter.
Chris Sunkin is offline
Old 09-09-2008 | 04:24 PM
Thx..
Teage sea strainers. SST./chrome... 1 1/4 Female NPT.. I need a male hose barb to go into the strainer so I can clamp the hoses to it. I found copper, for 1" hose. Found brass for 3/4' hose. Can't find stainless anywhere. Macmaster and Carr has something but I can't be sure it's a 1 1/4" NPT thread.
PARADOX is offline
Old 09-09-2008 | 04:31 PM
CPPerformance's Avatar
Originally Posted by PARADOX
Thx..
Try these out. Go all the way to the bottom of the page, straights, 45 degree and 90 degree.
CPPerformance is offline
Old 09-09-2008 | 04:33 PM
OutlawMark's Avatar
I think I have 4 of them at my house I'll check when I get home.I live in NPR you looked at my 37 AT
OutlawMark is offline
Old 09-09-2008 | 04:40 PM
OutlawMark's Avatar
these are what I should have
http://www.cpperformance.com/detail.aspx?ID=1028
Old 09-10-2008 | 09:07 AM
Thanks Mark,,, Those might work ok, I was trying to get stainless.. I remember your boat... saw it in the oso adds, and I see the price is better now.
You got to take that beast out.. Let me know when.. I might join you for a run or something.
PARADOX is offline
Old 09-10-2008 | 09:42 AM
Registered User
If you're screwing stainless into stainless, use a good liquid teflon pipe thread sealant or the bronze-based anti-seize. Or both. They may not gall going in, but they probably will coming out.
Old 09-10-2008 | 03:20 PM
OutlawMark's Avatar
Probably be out this weekend,weather looks good
Old 09-10-2008 | 04:11 PM
Mbam's Avatar
Offshoreonly Advertiser
Are you sure that is 1 1/4 thread? Typically the strainers are built with 1" NPT which happens to be close to 1 1/4 OD (standard merc sea pump inlet size).
We normally buy 6" x 1" npt nipples, put them in the lathe chamfer and turn down enough room for double clamps leaving a lip on the end. That way we get 2 fittings per nipple.
Mbam is offline
