Steering wheel replacement? >
Old 09-13-2008 | 03:22 PM
augie58's Avatar
Default Steering wheel replacement?
I am planning on replacing the steering wheel on my 98 353 Formula. What do I need to know when I go to match it up?
augie58 is offline
Old 09-14-2008 | 07:56 PM
trips2win's Avatar
depending on what you buy, i had to change the hub to match the pattern on the new wheel, mine is a 98 also, you should i think have the same shaft i thought mine had a slot and keyway.
trips2win is offline
Old 09-15-2008 | 11:15 AM
CPPerformance's Avatar
You can buy a wheel with the same bolt pattern or you can go to a different bolt pattern. If you go with a different bolt pattern you'll have to change the hub. Most are a 3/4 round tapered shaft. We have a large selection of wheels and hubs you can look at them here
or you can give me a call at the number below. Hope this helps.
Brian
CPPerformance is offline
Old 09-15-2008 | 04:12 PM
Strip Poker 388's Avatar
Rob
direct bolt up was easy
http://www.offshoreonly.com/forums/s...t=92301&page=2
call Ryan,he took care of me when I did mine http://www.kineticanimation.com/
Strip Poker 388 is offline
MOERON
07-23-2007 08:04 AM
Panic Button
Cigarette
8
06-28-2006 03:36 PM
SeaWeasel
05-23-2005 01:18 PM
briana
Fountain
11
03-11-2005 09:07 AM
GO4BROKE
11-11-2002 08:49 PM
