Imco PS reservoir leaks >
Old 09-14-2008 | 06:33 PM
GO4BROKE's Avatar
Default Imco PS reservoir leaks
My Imco PS reservoir leaks through the breather in the cap when in rough water. Anyone have a cure for this? Different cap or replacement breather?
The PT-9 in the pic is my part.
[img][/img]
GO4BROKE is offline
Old 09-15-2008 | 12:47 PM
dcb
I have the same reservoir in my '03 386, it leaks in rough water too.
dcb is offline
Old 09-15-2008 | 02:08 PM
CPPerformance's Avatar
Sounds like it is building pressure and bleeding out, you need a vent of some sort or run a different reservoir with a vented cap such as this------> http://www.cpperformance.com/SearchR...CategoryID=372
There are a couple to choose from in size and application. I can also get you a bung and cap to weld in place of your existing setup if you are a weldin' man Hope this helps, let us know if we can help more. Thank you
Brian
CPPerformance is offline
Scarab3DMC
0
08-25-2008 07:44 AM
BillR
04-25-2006 08:32 AM
Catagory5
Sonic
26
10-23-2005 09:01 PM
offthefront
3
04-17-2004 07:41 AM
rws
3
06-20-2002 10:09 AM
