Imco shorty's on a Formula 382? >
Old 09-18-2008 | 08:11 AM
OldSchool's Avatar
Default Imco shorty's on a Formula 382?
I'm posting this for a friend. He started a thread in the Formula forum and hasn't gotten any responses on that. Anyone?? See below:
382 with imcos 2" shorties
Has anybody done this with 500 with no boxes and gen, how do you think it will run? Because I have a buddy that needs drives and can buy those drives cheap, I know they have low water pickups only but it is a twin step.
OldSchool is online now
Old 09-18-2008 | 08:24 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
How is BobbyB's boat setup? I know its a lighter race boat, but I am sure its had several iterations tried on it. He may be of some help.
Sydwayz is offline
Old 09-18-2008 | 09:50 AM
OldSchool's Avatar
Thanks Brian. I just talked to Bobby and he doesn't have shorties on his boat. Anyone???
Old 09-18-2008 | 10:19 AM
t500hps's Avatar
21 and 42 footers
Call Formula TAG...they seem to be able to answer any question I've thrown at them, maybe they've already tried it? (but I doubt it)
t500hps is offline
Old 09-19-2008 | 12:28 AM
articfriends's Avatar
I would be surprised if it worked,Jeff wagoner (wags382) on here has a 382 w/warmed over hp 500's. Its making close to 600 hp on the dyno. He tried various props including labbed 28's,30's and maximus props. His boat went slower with the labbed 28's and 30's then it did with std 28's which would lead me to believe going up-2 would probably have a negative effect,if his boat slipped too much with labbed props,how would it ever work with drives moved up ( he never tried the shorties for this very reason) Smitty
articfriends is offline
Old 09-19-2008 | 01:09 AM
I think Formula sets there X pretty agressively. Even with the Stellings box option, they only raise the X dim up 1 inch.
Griff is offline
Old 09-19-2008 | 04:11 AM
RedDog382's Avatar
I think it would be a waste of time and money. Formula has put extensive research into these hulls and have the most efficient X-dimension worked out. If it was of benefit, every race hull that ran when they had a very successful F-2 campaign would have a raised X-dimension. Stellings boxes will only gain 1-2 mph on a 382 hull at best.
RedDog382 is offline
Old 09-19-2008 | 05:31 AM
OldSchool's Avatar
Thanks for the replies.
Old 09-19-2008 | 01:03 PM
offthefront's Avatar
there is a killer deal for imco -2 shorties in the Classifieds ..as new 2950 ... 2 cases with the verticals and AC plates ...
As stated though you see em all the time that people have tried and gained nothing ....look cool though ...m
http://www.offshoreonlyclassifieds.c...o25922-en.html
offthefront is offline
Lucky Strike Jr
07-19-2007 07:50 PM
GoFastSonic
Sonic
2
06-06-2007 04:24 PM
Toffen
07-28-2003 02:28 PM
bripar77
12-19-2002 03:04 PM
