stock Merc 502 efi cam , do i need different dist gear? >
Old 09-19-2008 | 01:07 PM
Default stock Merc 502 efi cam , do i need different dist gear?
I am using stock Merc Tbolt dist of my 454 gen5 on my new 502 gen6 with roller cam,
doI need a different gear on the dist or not?
HTRDLNCN is offline
Old 09-19-2008 | 01:24 PM
Pat McPherson's Avatar
Yes, buy a bronze gear or dist gear from Chevy HP.
Patrick
Pat McPherson is offline
Old 09-19-2008 | 07:10 PM
It actually depends on the cam gear.
Most people use a pressed on steel gear so you can run a stock steel dist gear. If its all billet, then you need to run a bronze or composite gear.
Griff is offline
Old 09-19-2008 | 08:41 PM
Frank, have you gotten any of my responses to your emails? They keep bouncing back saying your inbox is full.
Anyway, your stock distributor gear will work fine.
Bob
bobl is offline
Old 09-19-2008 | 09:22 PM
Bob,
thanks,
have gotten all your emails no problem.
See ya tommorow on the poker run if you go.
Frank
HTRDLNCN is offline
Old 09-20-2008 | 08:34 AM
PatriYacht's Avatar
The stock 502EFI cam is a Crane and they use pressed on cast gears so you can run a stock distributer.
PatriYacht is offline
mark30h
1
02-09-2008 12:08 PM
Strip Poker 388
4
02-13-2004 07:34 PM
Kanookstr
25
01-13-2004 08:47 PM
26sonic
8
04-22-2003 07:39 PM
