Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Single stage metallic, or two stage? >
Old 09-22-2008 | 12:57 PM
czy40p's Avatar
Default Single stage metallic, or two stage?
Had a little accident with tailgate and need to replace it and paint it. Currently have the reducer and hardener for single stage, but I am having second thoughts about using it with a metallic paint. (Dark Gray Metallic). I keep the truck clean, but not waxed, so I am not looking for show car finish. Just looking for some feedback on the single stage metallic aspect. I know the wet sanding polishing of the single stage is a going to show, but was thinking about mixing in some compatible clear with the top coat.
Jim
czy40p is offline
Old 09-22-2008 | 01:21 PM
tssteph's Avatar
base clear or it wont look right.
tssteph is offline
Old 09-23-2008 | 02:17 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
If shooting an entire panel thats one thing. If you are going to blend it is more likely to not blend or look blemished in my opinon as well.. Base clear I think would be the better way to go... Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 09-23-2008 | 02:35 PM
czy40p's Avatar
It would be the entire panel, leaning towards the BC/CC, depending on paint costs I may just let the bump shop do it.
Thank,
jim
czy40p is offline
Old 09-23-2008 | 03:19 PM
bc/cc. the metal flake in the singlestage likes to group and look blotchy, due to static electricity. unless you are a pro don't do it believe me I learned a very expensive lesson!
twin242ls is offline
Baja_man
Baja
7
12-04-2007 02:55 PM
carter38
11-04-2005 12:40 PM
Johnny Venomous
12
09-03-2005 06:50 PM
boat4life
4
03-10-2004 11:07 AM
