Supercharger on a 208 islander?? >
Old 09-22-2008 | 10:44 PM
Default Supercharger on a 208 islander??
Can I get some input on a supercharger on a 7.4 454 in a 1994 Baja 208 islander? I am debating on selling it to get a bigger faster boat or keeping it and putting a pro charger or whipple on it and saving until next fall to spend a littlemore money on a bigger boat.
1.Has anyone ever put a supercharger on a 21ft boat?
2.What kind of speed gain will i see?
3. Is this a safe idea only being a 21ft boat? all input is greatly appreciated. Thanks
justincasey57 is offline
Old 09-22-2008 | 11:01 PM
JasonSmith's Avatar
Ahhhh, I can teach you grasshopper.
You need to budget about 3 times what you think you will spend. You will need full hydraulic steering, upgraded drive components (assuming you have a Bravo drive) and a new propeller at a minimum.
You will then learn that your boat is going to be spooky at speed & your money should have been saved to buy what you wanted instead of settling on an upgrade to a boat that you aren't really happy with to begin with.
I won't say what I've spent on my boat, but I will tell you that is was too much.
JasonSmith is offline
Old 09-23-2008 | 01:34 AM
articfriends's Avatar
Words of wisdom,I wouldn't go crazy on a 208 islander,you will never be able to run any kind of real speeds with any degree of safety and every dollar you spend will never be re-couped when you decide to move up. It will actually be difficult to ever sell your boat once its modified because its at the entry level end of the spectrum and any mods will scare 99.9% of any prospective buyers,Smitty
articfriends is offline
Old 09-23-2008 | 08:15 AM
thanks for your advice.
anyone else??
Old 09-23-2008 | 08:23 AM
BAJA WILL's Avatar
Registered User
I would not advise it, by the time you spend money on steering, prop, you are just better off buying another boat.
That much HP in that hull could end up dangerous.
WILL
BAJA WILL is offline
Old 09-23-2008 | 01:55 PM
Do your research about boats and go get the boat you want that will do the speed you want. Seriously! re read the first sentence.
drpete3 is offline
buchnerbh22
Prop Talk
12
02-02-2012 06:42 AM
magstang1
Powerquest
6
08-17-2011 06:53 PM
justincasey57
Baja
11
09-22-2008 09:13 AM
BajaBuddy
Baja
1
07-24-2007 08:44 AM
Downtown42
08-28-2006 12:05 PM
