problem with 502 efi... Help!!! >
Old 09-23-2008 | 06:05 PM
Default problem with 502 efi... Help!!!
my starbord motor is droppin off when running above 3800 rpms tach shows it droppin 7 or 800 rpms then pickin right back up, more of a hesitation really Also has done cruising around 3000 but only when the water is rough, no problems what so ever starting, idling or even comin up on plain, I'm guessing fuel related but what exactly, fuel pump? Fuel filter? Opinions please... Thanx n advance
jmoore1225 is offline
Old 09-23-2008 | 11:34 PM
anything guys
Old 09-24-2008 | 12:24 AM
When was the last time it had a cap and rotor? After that I would check the screen in the bottom of your high press. efi pump fuel bowl module, On top of the motor. Then fuel pressure to see if it is dropping off. 38-42 psi.
speedreeder is offline
Old 09-24-2008 | 12:29 AM
Sounds like an electrical connection problem.
Griff is offline
Old 06-19-2011 | 09:01 PM
ballon78's Avatar
i know, its an old thread but having same problem with both my 502efi's...what did you find it to be. thanks
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 06-20-2011 | 06:20 PM
camptappakeg69's Avatar
Mine had a similair problem, clogged screen in the electric pump in the vst. Then the next year it got way worse...turned out to be the electric pump in the vst.
camptappakeg69 is offline
jmoore1225
Fountain
4
11-02-2008 08:47 AM
HiPerf2000
4
05-28-2008 04:35 PM
tanner
11-11-2006 05:26 AM
Smitty
2
08-20-2004 06:04 PM
blown formula
31
06-10-2003 06:59 PM
