intake manifold gaskets >
Old 10-01-2008 | 08:25 AM
Ken N's Avatar
Arrow intake manifold gaskets
I remover my intake manifold yesterday and notest that the stock manifold gaskets blocked off the front water passageway on one side and the back on the other side. The new set of gasket both sides are open. Should i use the flow throu type or the blocked off type.
Ken N is offline
Old 10-01-2008 | 08:42 AM
both should be open in the front. Someone put one on backwards. I've never seen solid rear hole gaskets before.
kennyo is offline
Old 10-01-2008 | 10:26 AM
Ken N's Avatar
Arrow intake gaskets
You are correct. I set the heads on the work bench the way they go on the engine, they are closed on the belling housing end and open on the circuleing pump end.Still my question is what gasket do i use open or closed in the rear?
Ken N is offline
Old 10-02-2008 | 07:01 AM
both sides of the intake gasket need to be open in the front..Rob
ezstriper is offline
Old 10-02-2008 | 07:03 PM
Ken,
You did not mention what type of engine you are working on but .... if you look at the intake manifold, I bet that there is no water passage across the back, so there is no need for a hole there, even though most gaskets will have it. Only thing I can figure is you are working on a small block Chevy and someone used a set of the gaskets for a mid 80's tbi setup which did have a coolant pasage across the back and the gaskets had a restrictor plate in the rear holes.
What exactly are you working on ??
Bill Koustenis
Advacned AUtomotive Machine
Waldorf Md
BillK is offline
CN24
2
11-23-2007 02:32 PM
Jassman
Active Thunder
20
10-01-2007 08:45 AM
dykstra
2
08-29-2005 05:39 PM
CN24
3
04-07-2005 03:33 PM
birdog
08-01-2002 08:30 AM
