Weather protection >
Weather protection
Weather protection
Old 10-01-2008 | 02:21 PM
Default Weather protection
I have a 1994 32 Active Thunder and I'm having trouble keeping water from pooling on the boat cover over the cabin hatches. Has anyone found a product that keeps the cover higher than the hatches so the water will flow towards the sides of the boat? If so could you advise where I can find the product at and its cost?
Offshore Drilling is offline
Old 10-01-2008 | 02:29 PM
Gladhe8er's Avatar
I saw one guy throw an upside down styrofoam cooler over the hatch. it protected water from getting in the hatch and raised the cover so that the rainwater would drain off the deck.
Gladhe8er is offline
Old 10-01-2008 | 03:28 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Throw a couple of styrofoam noodles under the cover, one over each hatch, lengthwise. That ought to remedy the water pooling.
Sydwayz is offline
Old 10-01-2008 | 08:13 PM
Thumbs up
I use foam "Boogie boards"; upside down they create a nice hump...
spilman is offline
Old 10-02-2008 | 02:10 AM
I use my garage
I would use something as suggested to lift the cover higher. Just make sure its something that won't leave a stain.
Griff is offline
Old 10-03-2008 | 11:28 PM
R Addiction's Avatar
AT Cult Member #3
RQuest, Where in MD are you from? We are from Tomes on the Susquehanna.
R Addiction is offline
Old 10-04-2008 | 09:22 AM
I take my two square throw cushions and put one on top of the hatch closes to the cockpit. The other one I put between that hatch and were the snaps start for the cockpit cover. Works great. Creates enough lift that water rolls off to the sides and down the bow of the boat.
James, were are the Modules!
flenner is offline
Old 10-05-2008 | 11:34 AM
R Addiction, I'm in St. Mary's County. To all thanks for the ideas.
Old 10-06-2008 | 09:13 AM
AT Cult Member #3
Wheres that near?
Old 10-06-2008 | 09:17 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Wheres that near?
That's Southern Maryland, way SE of DC, Solomon's Island, etc. etc; down by BobbyB.
Sydwayz is offline
