Go Back  Offshoreonly.com > Owners Forum > Sonic
I'm taking off my arch! >
Old 10-08-2008 | 09:45 AM
Registered User
Default I'm taking off my arch!
My project for the winter is going to be removing the arch on my 35ss..
Has anyone ever done this and any suggestions??
What should I use to cover the holes where the arch used to be??
Diffulcult or easy to remove??
Powerboat713 is offline
Old 10-08-2008 | 10:49 PM
I did. I'll PM with details. Covered holes with step pads.
sonicss42 is offline
Old 10-09-2008 | 06:32 AM
Registered User
What kind of step pads did you use???
Any pics?? Before and After??
Old 10-09-2008 | 08:00 AM
45sonic's Avatar
Unbolt it, unwire it, then get some of the biggest friends you have to break it loose from the 5200 holding it in place then carefully lower from boat to ground.
As far as the holes. Either step plates which I have not really seen any that look all that good OR fill the holes and regel or repaint to match boat. Mine was filled and painted as were two other friends boats that removed their arches also.
45sonic is offline
Old 10-09-2008 | 02:45 PM
johnny g's Avatar
it is alot heavier than you think!
johnny g is offline
Old 10-09-2008 | 04:15 PM
45sonic's Avatar
You ARE correct about that.
Even more so if antennas and spotlight are on it.
45sonic is offline
Old 10-09-2008 | 11:16 PM
Z06
Yes it is!
Reminds me of a freinds 42 sonic, he hooked a crane to the arch to support and lift it off. Unbolted the arch and proceeded to lift the arch, the back of the boat was off the trailer and the arch still wouldn't come off.
Z06 is offline
Old 10-13-2008 | 09:17 AM
johnny g's Avatar
Me and my son took mine off. Liked to broke our backs! I would definately recomend some type of lift to get it off.
johnny g is offline
Old 10-13-2008 | 09:20 AM
Registered User
I will be taking it off at my marina and I am sure they will help me if I need the forklift.
Old 10-25-2008 | 09:33 PM
Default Arch Removal
It is heavy and it is stuck on with a really strong adhesive. It took a few of us to remove it. I filled the holes and painted the boat, I think it looks a million times better.
Boaties is offline
