Anyone try spinning a 350 mag mpi backwards? >
Old 10-12-2008 | 08:58 PM
Default Anyone try spinning a 350 mag mpi backwards?
Got any ideas why it wouldn't work..
HaxbySpeed is offline
Old 10-13-2008 | 01:13 AM
HUH?????????? Why would you want to?????
Griff is offline
Old 10-13-2008 | 06:38 AM
you will have to change the cam to a reverse rotation cam, a special delco dist and rear main seal...Rob
ezstriper is offline
Old 10-13-2008 | 02:25 PM
I've got a customer who wants to repower an older inboard boat that has counter rotating 260 mercs. The transmission cannot be converted to spin in reverse, and there is no room for a different trans..
The cam and distributor aren't a big deal and the crank trigger should work fine in reverse, I think the new ones might have a cam sensor as well... The injectors are batch fired.. I think it can be done unless there's something simple that I'm missing. Which is often the case..
Old 10-13-2008 | 02:44 PM
they still sell reverse rotation gm small blocks already done...Rob
Old 10-13-2008 | 02:57 PM
EFI?
Old 10-13-2008 | 03:33 PM
jrz
I recently had a 350 MPI changed to reverse rotation for the same reason. 1951 Chris Craft. Everything seems to work fine.
jrz is offline
brick1932
7
09-21-2007 08:07 AM
JGB
1
02-25-2005 11:12 AM
Rumrunner-fishing
7
04-13-2004 07:21 AM
justinVIP
17
11-18-2003 10:43 AM
