Temp Gauge
I am looking for a temp gauge for my 242. It seemed fine when I was winterizing yesterday until I started it up to get the engine warm again after changing the oil to run the antifreeze thru the engine. The gauge never moved, I checked the connections under the dash all seemed fine. After all these gauges are only 21 years old.
Any one have and extra laying around they would sell or is it time for new gauges. What is the best way to get the bezels off screwdriver?
Mark
Mark
you need to check the sender on your engine before you go changing gauges. should be a tan wire. Ground this out and see if your gauge moves. If it moves then replace the sender. If not you will need to do a bit more testing under the dash before proceeding. I do have a gauge if you end up needing it.
The guages on the 34PC mount flush with the panel face, no square bezel. I believe they will still work with the bezel style. Is this correct?
