2001 F 350 Need  More Power ! Help >
Old 10-23-2008 | 06:42 PM
Default 2001 F 350 Need More Power ! Help
HI . i have a 2001 f350 4x4 7.3 powerstroke , with k&n air filter , bullydog programer , looking for more power ??? i just bought a 2009 raptor 40 ft toyhauler , gooseneck , just hooked it up last night and boy what a load , worked the tar out of my poor ford ,, anyone have any ideas ?? im think 4in exshaust for starters ???? Help !!
elroy521 is offline
Old 10-23-2008 | 07:19 PM
The best bang for the buck would be
BUY A GMC!!
Jesse James is offline
Old 10-23-2008 | 07:20 PM
FASTTIMES's Avatar
I'm really not sure of the best package for the 7.3's, they are stong motors but have heard they take $$$ to build allot of power. You might try searching on "thedieselgarage.com" they have a 7.3 truck forum and 7.3 chip and tuner forum.. I'm sure other guys will chime in- - you should be able to get the 7.3 where you want it with the right parts
FASTTIMES is offline
Old 10-23-2008 | 07:21 PM
BEST OF LUCK FINDING THE POWER IT SUCKS BEING UNDERPOWERED WHEN TOWING. sorry for the caps
Old 10-23-2008 | 07:55 PM
FASTTIMES's Avatar
BUY A GMC!!
the duramax is a strong motor and I would own one myself. My buddy has one that will run like a raped ape.. I believe the superduty is a better overall platform for towing--- but you know what they say about opinions
Old 10-23-2008 | 11:09 PM
DP tuner 828-221-0076 you'll be glad you called. Get the exhaust,too! Bob
Bob280Silencer is offline
Old 10-23-2008 | 11:32 PM
bigandy's Avatar
chapest bang for your buck, unplug batteries overnight. next morning drive the crap out of it all day long, like an 18 yr old in a stolen car. it reprograms the PCM , shift points in the tranny and injectors.....
bigandy is offline
Old 10-24-2008 | 07:20 AM
DRIPPINWETII's Avatar
Def exhaust and down pipe then injectors.
http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__100-HP-7-3-Ultimate-Powerstroke-injector-rebuild-kits_W0QQitemZ330280404282QQadiZ2865QQadnZCarQ20Q2 6Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZViewIte m?hash=item330280404282&_trksid=p4506.c0.m245&_trk parms=72%3A543|65%3A12|39%3A1|240%3A1318
DRIPPINWETII is offline
Old 10-24-2008 | 07:44 AM
seafordguy's Avatar
This is the tuner that everyone swears by for the 7.3.
Also check out thedieselstop.com - that is an entire website dedicated to the powerstroke and it has a TON of info on it.
seafordguy is offline
Old 10-24-2008 | 09:20 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Look www.lightning-motorsports.com They are outside of Tampa. Both owners, Mark and Tom have 7.3L trucks and know a thing or two about them. Mark and Tom are both boat owners and OSO members, and I don't do anything to my truck(s) without running it through them. I also buy almost everything through them.
My suggestions:
Get rid of the K&N Filter/FIPK. It is the WORST setup for the 7.3PSD. There are MANY, MANY whore stories about this setup on www.thedieselstop.com . They do NOT filter well enough for the 7.3L PSD.
I run www.truflow.com on my 7.3L PSD.
What is your rear end ratio? 3.73 or 4.10? If it is a 3.73, swap it out to the 4.10. You will see a significant difference.
Get a big ass exhaust from the turbo back. I am happy with my MBRP system. An engine is a giant air pump. If you want to pump more air into it, you have to be able to pump more air out of it.
Dump the Bullydog switch, and get a DP Tuner. I too run the Bullydog, but I know the DP is much better.
www.dp-tuner.com is the only one that you can order "ala carte" with the exact options on it that you want.
Last step is beginning to get into the motor involving bigger injectors and a bigger turbo. These are not trivial, and need to be done right. They also may accelerate a rebuild time on your engine due to how much power they are pushing through the motor. Be prepared for headgaskets first, and maybe more.
Priceless resources:
www.innovativediesel.com
Last edited by Sydwayz; 10-24-2008 at 12:10 PM. Reason: Confused SCT with DP; fixed.
Sydwayz is offline
