Stringer delamination?
I just finished winterizing. As I was pulling the port battery I tapped the stringer and found the glass is loose from the wood for about six feet. Is there any such thing as an easy repair or should I just start parting out the boat.
Fixing is NEVER easy.
But it can be fixed .
Did it justcome off or is the wood rotten ?
If it just delamed then cut it of grind the wood and reclass, overlap on each side (about 6 ") and repaint with gelcoat .
