Go Back  Offshoreonly.com > Owners Forum > Sonic
External GPS Speedo >
External GPS Speedo
External GPS Speedo
Old 11-01-2008 | 06:19 PM
Plum_Crazy's Avatar
Default External GPS Speedo
I have Garmin GPSMAP 540 on the dash of my 31SS. Since I'm the only one that can see it, I'd like to add an external GPS speedo to the port side. It would run off the NMEA output wire. However, I can't figure out how to get the wire over to the other side. I don't want to break the seal around the headliner. Is there another way?
Plum_Crazy is offline
Old 11-02-2008 | 08:00 AM
Sonic typically runs a pvc chase under the floor from the galley cabinet to the dash, I know this to be true on the 358 and up and pretty sure they do it on the 31 as well. You will have to reach into the bottom of the cabinet at the galley and pull the carpet back which is held in with spray contact. At the back side of the dash the the chase should enter in at the bottom of that cavity
Sonic Steve is offline
Old 11-02-2008 | 09:16 AM
Plum_Crazy's Avatar
Thanks, I'll check it out.
Old 11-03-2008 | 07:57 PM
Plum, As Sonic Steve said there is a rigging tube running underneath the cabin door. You can see it if you look down through the dash access door above you toilet. If you take off the dash panel on the passenger side you'll be able to bring any wiring up through the cavity behind the dashboard cooler. Those rigging tubes make it so nice when you want to do upgrades! Steve
509 SC is offline
Old 11-03-2008 | 10:15 PM
Plum_Crazy's Avatar
Yes, I dug into the boat tonight and found the pipe. It will be a challenge feeding the wires through, but I'll get it. I plan to mount the speedo and recall switch on the pass side dash panel.
I'm thinking about getting a new pass side dash panel while I'm at it, maybe in blue instead of white. Does anyone know what they cost?
Old 11-04-2008 | 07:16 AM
45sonic's Avatar
We have been using a tinting process with paint and clear to do dash plates and panels. Find me a color blue you like, send me the panel and we can make it happen for you. We did this on our Sonic switch plates in red and they came out great.
Attached Thumbnails External GPS Speedo-process.jpg   External GPS Speedo-almostdonedash.jpg
45sonic is offline
Old 11-04-2008 | 11:02 AM
Plum if you want to try this. In my 31SS I mounted the GPS pick-up under the dash. First I used tape to see if I had a good location. then I made a bracket under the dash it worked great. I just hate drilling holes in the boat if I don't have to.
45SS is offline
Old 11-04-2008 | 08:51 PM
Plum, Just use a electrical fishtape for running wires through the tubes. Steve
509 SC is offline
Old 11-05-2008 | 03:31 PM
Plum_Crazy's Avatar
Oh, yea. That's what I plan to use. However, there's lots of hoses and wiring already in the PVC chase. It's pretty full.
tgersx
3
06-09-2007 09:27 AM
tgersx
06-08-2007 05:18 PM
Pure Energy
06-23-2003 10:37 AM
Andy Buzz
04-08-2003 10:00 PM
kaamacat
3
11-30-2002 03:04 PM
