Fogging  fuel injected big blocks for winterization >
Old 11-03-2008 | 09:00 AM
bigboat28's Avatar
Default Fogging fuel injected big blocks for winterization
Can you fill the fuel water separator with 2 cycle oil and run the engine to fog it. If so how much 2 cycle do you put in the separator. Also can you drain the motors with the drain on the bottom(blue plastic wing nut plug), will this drain the whole motor including exhaust and water pump impeller housing then pour in antifreeze through the thermostat to fill block. Will this work and be safe like they are saying in this last issue of Powerboat?
bigboat28 is offline
Old 11-03-2008 | 10:08 AM
Elite Marine's Avatar
We use a cocktail of 2 cycle oil, Mystery Oil and Sea Foam in the separator until the white smoke starts coming out of the exhaust.
As far as winterizing the blocks, Merc recommends simply draining. I dont know whick engines you have but most have drains on the blocks, coolers and the exhaust.
I prefer to drain it complete and then i fire it up on -100 glycol and then I drain it again...call me anal I guess!
Elite Marine is offline
Old 11-03-2008 | 10:48 AM
t500hps's Avatar
21 and 42 footers
Did mine this weekend.....Stabilized the remaining 10 gallons of fuel in the tank (no fogging oil). Ran it on the hose til at operating temp. Shut it down and drained it, then re-fired it on antifreeze. Then drained it again and removed the seawater pumps so new ones can be installed in the spring (or re-use these since they look good). this waws done right after I changed the oil and filters too.
t500hps is offline
Old 11-03-2008 | 12:44 PM
bigboat28's Avatar
I have the 6.2's, they have the drains on exhaust and thermostat housing and then one low one with the block plugs running to it.
Old 11-03-2008 | 02:38 PM
Do they have drains on the coolers too?
Old 11-03-2008 | 03:05 PM
offthefront's Avatar
No ....smart .....
offthefront is offline
Old 11-03-2008 | 06:43 PM
Isn't it better to leave the antifreeze in the system, assuming it has corrosion inhibitors in it?
MacGyver is offline
Old 11-03-2008 | 07:03 PM
I drain the water first then fire it up on the antifreeze and leave it in for the corrosion inhibitors. And when its first fired in the spring I like the idea that the antifreeze is slippery for the sea water impeller to start turning in after sitting for a while.
johnny b good is offline
Old 11-03-2008 | 07:29 PM
t500hps's Avatar
21 and 42 footers
That's why I remove the seawater pump for the winter...leaving the impeller sitting outside of the housing during the winter allows it to last alot longer than normal.
t500hps is offline
Old 11-06-2008 | 06:50 AM
I've always used the water separator as the insertion point for fogging. I will drain out half the fuel and add a couple ozs of 2-cycle oil, fire up until smoking then shut down and replace the filter. However after burning a hole in the piston last year at the beginning of the season I have added sea foam to the mix as kirk has sudjested.
Naughty Kitty is offline
