fastest 271 sr1??? >
fastest 271 sr1???
fastest 271 sr1???
Old 11-23-2008 | 07:13 PM
Default fastest 271 sr1???
I have a 271sr1 with 600hp that i am trying to get to go faster. Right now the best ive seen is 72 gps. Since then, I have had the bottom worked on and much of the hook has been eliminated. I am also building a 800HP N.A. motor for next season.
My question for anybody out there is if anyone has heard of someone with a similar boat (even fastech) and what was their setup. I don't know if a stand off box will help or not. It hasn't chine walked yet, but i am sure it probably will over the 80 something mark. I am thinking it could make it into the mid 80s.
Anybody know of a similar setup or have any advice?
formulaok is offline
Old 11-23-2008 | 08:10 PM
Charter Member #415
A 271,step or non step,will not see mid 80's with even 800 hp.The 271 is a great boat as long as you accept that it will never be very fast. It is just a very nice gentleman's performance boat with high quality,a solid ride,and is very happy with the speeds it is capable of.
Magicfloat is offline
Old 11-23-2008 | 08:40 PM
t500hps's Avatar
21 and 42 footers
A members boat....(cut and pasted from his ad)
2000 / 271 Fastech. 500 EFI, 509 cu.in. AFRs CNC w/315 runners, Bob Madera cam, JE 9.6:1 pistons, EMI exhaust, XR drive 1.5 ratio, Bravo 1 labbed, IMCO steering. Engine has around 20 hours since build. Dynoed 572 HP @ 5400, 606 TQ @ 4400.
He later posted the boat ran mid 70's.
t500hps is offline
Old 11-24-2008 | 10:54 AM
Default 2000- 271
540ci n/a 583tq 546hp 78.2 gps tops Lake Mich 1' chop will run 72.4 all day long 30p non lab , 3/4 fuel 1 person , 2people 70.2 gps blue printed haul 1" shorty, More to come this spring of 2009 looking for low 80s
tony manzella is offline
Old 11-24-2008 | 07:42 PM
That's pretty impressive. I just had my hull worked on to remove the hook. they weren't able to remove all of it without filling in forward. It was going to cost too much to remove it completely. Does your bottom still have any hook left?
Old 11-25-2008 | 08:18 AM
Default H O O K !
YES ! THE LAST 3.5 TO 4"
Old 11-25-2008 | 08:24 AM
formulaok . where are you located may be able to help - P.M me . good luck with her!
Old 11-25-2008 | 04:07 PM
Im in Oklahoma City, Usually boat at texoma and go to LOTO 2 or 3 times a year.
I "built" this boat last spring. We raised the x dim 2" and installed a modified 525sc. Out of the shoot it ran high 60's. Then I swapped the drive for a bmax. It slowed it way down to 64. The gearing was way off. I then raised the boost as much as possible and did some more tweaking which got me into the 70 mark. I now have worked on the bottom and have swapped the bmax to an xr.
The motor I am changing to this winter is a 609ci N.A. mechanical roller motor that should be better than 800 h.p. and turn around 6000rpm.
I know I am going to have to go easy on the sticks to keep from blowing the drive off the transom, but weve done it before!
Old 05-03-2009 | 12:54 PM
1997 fastech w/ 600 Volvo converted to merc bravo set up. Ran a best of 76 and change GPS on chesapeake w/ 28" non lab bravo
merkruzer is offline
formulaok
0
03-19-2008 04:07 PM
dockrocker
07-19-2004 09:11 AM
rlavigne
03-18-2004 02:03 PM
bsc
02-23-2003 08:33 PM
olemissalum
08-25-2002 08:09 PM
