Oil coolers with stats
Pirate of the Chesapeake
Thanks guys got my starters figured out.Now has anybody used the CP oil coolers with the built in stats.Would like to use them because of less plumbing than the remote stats fewer connections .Thanks JOHN
John,
I have used them several times and have never had any problems with them. I used them for just the reason you mentioned...less plumbing or lack of room for the big thermostatic oil filter mount. I would not hestitate to use them again. I would say I have used about 20 of them over the last few years. I think you will be pleased with them.
Eddie
Eddie
Feel free to give us a call and we can talk about your specific application, I have had nothing but pleased customers with these, you might also check out the plate coolers if you are restricted on space, they are more efficient and not as big- http://www.cpperformance.com/detail.aspx?ID=211 Thanks,Brian
John .... I assume your talking about the coolers shown here .... I used the external KE thermostats and have not been happy with them ...only way I can get any benefit is if I run hard for a long time ... They do me no good under normal conditons ( oil too cool) I had to bypass the water around the oil coolers to get to 200*....m
Offthefront. You say that the ke on the right was not good for you. Have you tried the cp on the left or is the picture just for reference. That's the one I think I want to use.Thanks JOHN
Right I have the remote T'Stat (on right) .... If I did it again I would try the cooler with the built in Stat ...By the time you add a regular Cooler and a remote Stat and fittings and hoses the combo is prob cheaper .....m
