Suggestions Please - Crank Case Venting >
Old 12-03-2008 | 04:30 PM
Default Suggestions Please - Crank Case Venting
I have the standard crank case vent hose that is routed back to the throttlebody. Needless to say, the intake gets a constant coating of oil from either minimum blow by and/or oil pan windage...
Is there a nice looking can that can be purchased to capture or filter this? I want something that is nice looking as well as functional. I'm picturing a real small version of a nice sea strainer with a billet top or something that matches engine colors.....
SDFever is offline
Old 12-03-2008 | 04:54 PM
I would think something along the lines of a aluminum can/box with mesh (like course srubbing pads) and then vented to the intake after filtered....and a way to drain would work....been thinking about something along those lines well...Rob
ezstriper is offline
Old 12-03-2008 | 04:56 PM
BY U BOY's Avatar
http://www.cpperformance.com/SearchR...CategoryID=172
BY U BOY is offline
Old 12-03-2008 | 05:51 PM
Boater8987's Avatar
Airking
Default Stef Puke tanks
Here are 2 Stef crankcase vents puke tanks. They have drains and are set up with AN fittings for stainless line and BBC mounting brackets. Will bolt to top bell housing bolts. You can use 1 tank per motor with AN tee. They have been sitting in my basement for only 10 years. Cheap, make me an offer. If you cannot see pics give me your em address to send pics.
Thanks Gary C-703-477-9071
Attached Thumbnails Suggestions Please - Crank Case Venting-p1000519.jpg   Suggestions Please - Crank Case Venting-p1000520.jpg   Suggestions Please - Crank Case Venting-p1000521.jpg
Boater8987 is offline
Old 12-03-2008 | 07:42 PM
CPPerformance's Avatar
Exactly, thanks.
CPPerformance is offline
betitbig
06-04-2006 05:22 PM
JERSEY DEVIL
Prop Talk
13
03-10-2006 10:46 AM
tomcei
5
10-01-2005 10:31 AM
Hot Boat
3
03-25-2005 03:34 AM
seahawk
13
01-11-2003 09:41 PM
