(real) HID headlight education
Old 12-03-2008 | 10:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default (real) HID headlight education
I've got three vehicles that I'd like to upgrade to REAL HID lights, with ballast and everything. Obviously, there is a lot on eBay, and most of it is cheap imitation "blue" "xenon" bulbs.
My headlights are as follows:
H13 Ford Superduty (integrated hi/lo in same bulb)
9006/9005 GMC Yukon (separate hi/low bulbs)
want to convert foglights too, but not sure of bulbs
H7/H1 Mercedes Benz (separate hi/low bulbs)
H1 foglights
I am pretty certain that I want to covert ALL of them, hi/low/fogs to HID. I want to make sure I get a quality setup. I want to make sure I am not going to melt any housing.
Can anyone offer advice? Does anyone have experience with aftermarket conversion setups? Is there a preferred/dominant vendor?
Thanks in advance.
Sydwayz is offline
Old 12-03-2008 | 10:38 PM
I went to pia offroad lights that are the strongest without installing a ballast. I now have more light than I need. with pia you are getting a quality bulb rather than a chinese knockoff
KrystalTransport is offline
Old 12-04-2008 | 09:11 AM
tblrklakemo's Avatar
SeaRay Sundancer
The HID Outdoor Equipment lights on ebay are the real deal....ballast and all. They are like $58 too.
Work very well on our Trailblazer SS. Wont ever go back.
tblrklakemo is offline
Old 12-04-2008 | 09:34 AM
Wally's Avatar
Were doomed!
On your Yukon.....i have a Tahoe with the same bulbs...from what ive read on other sites its not worth spending the coin for the real HID's cause it places the bulbs deeper in the housing and doesnt use the refective properties of the houseing right...again just what ive read....what i did was upgrade the bulbs to the sylvania silverstars...huge difference and nice and bright now...$30 well spent.
-Wally
Wally is offline
Old 12-04-2008 | 09:36 AM
Wally's Avatar
Were doomed!
Oh and another thing i did was also upgrade the wiring supplying the bulbs.....the stock wiring draws juice from the headlight switch...ever go on a long trip and feel the switch before shutting it off???? it get damn hot! I made a harness with two relays for each side and the bulbs now draw juice straight from the Batt....the switch never warms up now its only used as a trigger for the relays
-Wally
Wally is offline
Old 12-04-2008 | 10:56 AM
Post a pic of that harness and so ,please. I whant to do that to my suburban. Its a 96 though.
DareDevil is offline
Old 12-04-2008 | 11:48 AM
FASTTIMES's Avatar
Can you provide a link to the EBAY HID's that ARE good?
Thanks in advance!
FASTTIMES is offline
Old 12-05-2008 | 11:09 AM
Wally's Avatar
Were doomed!
Daredevil, what i ended up doing was getting some plug from an auto parts store and making up a harness to plug inplace of the orriginal light socket plugs......so basicly all you have to do is hook up batt +/- and run the plugs up to the headlights and unhook the orriginal plug and plug those into the harness and plug the new socket into the lights....that way if i ever decide to get rid of the trucvk i can put it all back to stock so the next guy doesnt have to try figuring it out incase a relay or something goes bad.....and if it does happen to go bad when on the road you can also go right back to stock in about 3min
I can draw up a schematic for ya and post it up or email you if you like
-Wally
Wally is offline
Old 12-15-2008 | 10:09 AM
SeaRay Sundancer
Thanks in advance!
Just search for HID kits and "hid outdoor equipment" is the seller.
There are other places on the net that have kits for 100 and another for 188......but who knows if they are the same, just marked up.
Old 12-15-2008 | 10:20 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It took some searching, but this is the seller I think you are referring to:
HID Outdoor Equipments is the STORE.
http://stores.ebay.com/HID-Outdoor-Equipments
Seller:
http://myworld.ebay.com/ebaymotors/lighting623/
You have to be very specific in the search query.
Sydwayz is offline
