octane on stock 454 Mags? >
Old 12-06-2008 | 04:46 AM
Default octane on stock 454 Mags?
I've done some searches and couldn't find anywhere what Mercruiser recommends. I have 2 boats: one with a 1992 454 Mag. Carb engine 365HP. One with a 2000 MAG MPI 385HP. I've always run 89 or 93 in the Carb 454 is 87 OK? I'm pretty sure 87 is fine in the MPI engine but want to make sure.
boater454 is offline
Old 12-06-2008 | 06:09 AM
I have 1995s with EFI. I was running mid range like 89 for years. My mechanic said I was wasting my money. Been runnuing 87 for a long time and no problems and no difference in performance.
Jeff
jeffgrice2 is offline
Old 12-06-2008 | 08:19 AM
they are set up to run on 87, in my area if you buy on the water thats your only choice in most places...
ezstriper is offline
Old 12-06-2008 | 08:34 AM
I can tell you first hand, if its says 87 thats what you should run 92 is a waste of $$. You will also notice alot less soot on your transom.
26sxl is offline
Old 12-06-2008 | 09:48 AM
The only thing you might consider is when you store your boat for long periods of time, I read gasoline can loose up to a half a point of octane value a month. So I top off with 93 octane and fuel stablizer for winter storage. The marinas by me only sell 89 or 93 even though Merc says my 502 mags will run on 87.
johnny b good is offline
Old 12-06-2008 | 03:37 PM
The lower the octane, the easier and more completely the fuel burns. They will make the most power on 87 and have less soot on the transom. Both the carbed and efi 454mags are designed to run on 87 octane.
If you are always running 89 octane, then you can advance the timing 2* to 34* total.
Griff is offline
Old 07-03-2021 | 01:45 PM
mercruiser manual #16
kroot is offline
Old 07-03-2021 | 01:46 PM
mercruiser service manual #16
kroot is offline
shotjock
5
01-04-2008 08:54 AM
onesickpantera
Eliminator
16
10-07-2006 05:57 AM
TRYME
16
08-20-2006 08:06 PM
Cruz-N-Thunder
1
07-22-2004 04:19 AM
delsol
8
05-09-2002 12:08 PM
