Sportmaster lowers >
Sportmaster lowers
Sportmaster lowers
Old 12-06-2008 | 01:19 PM
boatfreak's Avatar
Default Sportmaster lowers
Has anyone ever run a set on one of these 37's and if so how did it work? I'm thinking Tom "rockclimber" put on something similar and the boat didn't like it but he may have been running shorties. I'm really wanting the set in the swapshop section on here but not real sure how well my boat will like it. I think I could use the gearcase shape to help my on through the 90's. Thoughts?
boatfreak is offline
Old 12-07-2008 | 04:33 PM
crb76's Avatar
I believe Thunderstruck (Dan's first 37) had sportmaster lower. I think they were IMCO
crb76 is offline
Old 12-12-2008 | 06:27 PM
ActiveThunder's Avatar
Don't do it. (now that would be my thought)
ActiveThunder is offline
Old 12-13-2008 | 11:39 AM
there you go
JustGolf5
JUSTGOLF is offline
Old 12-13-2008 | 01:14 PM
boatfreak's Avatar
What's your secret on preventing writers cramp with answers like that?
P.S. Thanks
Last edited by boatfreak; 12-14-2008 at 09:18 AM. Reason: because one m can make a bid difference
Old 12-13-2008 | 03:54 PM
t500hps's Avatar
21 and 42 footers
I seem to remember excursions 37 was set up with a higher X dimension.......and he had to put spacers in his drives to get it dialed in. (check with him, I'm not sure I have my info correct)
t500hps is offline
Old 12-13-2008 | 09:09 PM
excursion's Avatar
Yes, Russ is correct, I had 500';s with standard bravo's,, without spacers with 30 bravo's had 23% slip, and put in a 1'' spacer went too 14% slip in turn picked me up 3-5 mph and cruise 5.
Up is not always the answer.
My boat was special, just faster than most with the same power, awsome boat.
excursion is offline
Old 12-14-2008 | 07:37 AM
boatfreak's Avatar
The sporties I am refering to a standard length so I assume they wont change my "x". I am just looking at the case shape as I am in the low to mid 90s now and I've got some ugly slip numbers with that. Just like a nosecone I figured I could get more water to my props with these lowers.
Old 12-14-2008 | 08:16 AM
You want shortees with 5 bladers. (now that would be my thought)
Old 12-14-2008 | 10:12 AM
Excursion is right. When I got the boat it did not have the spacers (high slip %). I went with 5 blades and it made a big difference! Got the same performance gains as he got with the spacers. There are a set of standard sporties at the shop right now that I am thinking of trying in the spring.
flenner is offline
