Raw Water Pump Change over >
Old 12-06-2008 | 09:16 PM
BajaExpress's Avatar
Default Raw Water Pump Change over
My express crusier has 454 330HP engines with Alfa drives.
Can I elimate the outdrive pumps and install crank mounted pumps and through hull water pickups for better cooling ?
How reliable are the crank mounted pumps?
BajaExpress is offline
Old 12-06-2008 | 09:49 PM
I would leave them ,just make shure that the impeller is good.
I would put a water press. gauge in the boat ,thatway u be more secured.
But they work fine and actually are lower in the water then other PU .
DareDevil is offline
Old 12-07-2008 | 01:22 AM
Sounds like a lot of work and money for nothing. The pumps in the Alpha's should pump plenty of water.
Griff is offline
Old 12-07-2008 | 01:48 AM
Griff,,,,how come we always think the same but you find the better words ?
Are you a lawyer ? LOL
Old 12-07-2008 | 09:11 AM
well to buck the other replys, you can do it if you want, need to put a scoop type thru-hull in the bottom of the boat, seacock on the inside along with a strainer, then mount up either a std merc inboard/bravo or crusader pump and braket setup, but the only thing i see you would gain would be the ability to change the impellor with out pulling the boat out of the water, unless the internals of the drive is corroded badly...Rob
ezstriper is offline
Old 12-07-2008 | 11:43 AM
boatman22's Avatar
BajaExpress, if you decide to go with crank mount pumps, I have 2 brand new Johnson F5B-9 crank pumps that I will sell.
boatman22 is offline
Old 12-07-2008 | 01:51 PM
Definately not a lawyer. A lawyer would have typed 2 paragraphs to say the same thing
Griff is offline
Old 12-07-2008 | 01:52 PM
LOL
Old 12-08-2008 | 06:18 AM
and no one here would have had a clue what the hell you said !
masi242
06-05-2008 07:47 PM
JJONES
9
02-17-2008 04:03 PM
Fenderjack
3
01-12-2008 02:55 AM
jdub
7
03-26-2007 05:06 PM
CHAOS REIGNS
1
06-20-2005 10:10 AM
