degreeing a camshaft ??? >
Old 12-07-2008 | 03:42 PM
Default degreeing a camshaft ???
Hello All,
I'm degreeing my camshaft by bring the intake valve up to full lift, then rotate the engine .100 backwards , then rotate forward .050 and record then rotate another .100 and record. My intake valve measures as the cam card reads , but when I do the same process on the exhaust the max lift reading is way off . I t should be 117 degree's and reading 242 degrees. I checked it several times and come up with the same readings. Now if I read the cam using the opening and closeing method at .050 the cam reads very close to the cam card. Any suggestions. Thanks
alecsammy is offline
Old 12-08-2008 | 07:05 PM
HotPursuit's Avatar
make sure your checking @
intake open= before TDC
intake close=after BDC
exhaust open =before BDC
exhaust close= after TDC
HotPursuit is offline
Old 12-08-2008 | 07:52 PM
Check this out... http://www.iskycams.com/degreeing.html
BenPerfected is offline
GNJ
4
11-07-2007 09:19 PM
blue thunder
12
02-04-2007 04:13 PM
KEPP
0
05-19-2005 02:39 PM
humpster
0
08-18-2004 10:19 PM
timucin
8
11-24-2003 12:08 AM
