water pres
Old 12-09-2008 | 04:32 AM
Default water pres
Help please, where I can install water presser gauge? On the block or on the intake manifold?
safesearaceer is offline
Old 12-09-2008 | 05:34 AM
either side of the block or the t stat housing.
What motor/year?
PJDiesel is offline
Old 12-09-2008 | 12:11 PM
In the block drain plug hole or in the intake manifold. The ones in the block drain tend to clog easily if you run in any shallow water.
Griff is offline
Old 12-09-2008 | 12:50 PM
What motor/year?
At the present it is set on the thermostat housing. I have 15 PSI pressure on the gauge. I would like to know what is the safest pressure to have on the block or intake manifold cos i am experience a problem at 4000RPM the inlet hose on the fresh water pump is blowing. temperature with thermostat housing is always to normal.
Old 12-09-2008 | 02:38 PM
25psi is about the max you want. You shouldn't being blowing hoses even with 40 psi though.
Griff is offline
Old 12-10-2008 | 11:42 AM
when i put on the thermostad i find a blow hose always the same one. from the pump to the oil cooler.
Old 12-10-2008 | 11:48 AM
Rookie's Avatar
Have you back flushed it to look for impellor parts clogging it?
High pressure before cooler and lower pressure after the cooler.
Rookie is offline
Old 12-10-2008 | 12:04 PM
I agree, check for an obstruction in the oil cooler. Water should flow through it almost as fast as a straight hose.
Griff is offline
Old 12-10-2008 | 12:09 PM
i checked all the hoses and the cooler, ok and clear.
Old 12-10-2008 | 01:22 PM
is this a new problem ? if so what did you last change also I run W.P. gauges at my helm also run pressure relief valves and dumps off the side
eliminatethis is offline
ThirdBird
05-19-2004 02:44 PM
CigDaze
12-14-2003 12:46 PM
GNJ2
1
06-02-2003 03:18 PM
chaser
09-15-2002 06:58 AM
