Boatring in S. FLorida Mon. and Tue. Dec. 15 and 16
Anybody going to be on the water Monday or Tuesday? I am buring a couple of vacation days and will be out somewhere between Pompano and Miami.
I have to work next week, but I am burning my days( and a ton of this cheap fuel while it lasts) the following 2 weeks if your around.
Rick, you don't really need the scan tool. All it does is cycle the ABS pump instead of you turning the key on and off. Some GM ABS units have their own bleed screws. They can be bled the traditional "pump-hold-release" method. Otherwise the ignition key can be cycled and eventually you'll refill the ABS unit.
Good luck...
HIJACK OFF
