Go Back  Offshoreonly.com > Owners Forum > Sonic
Sonic construction >
Sonic construction
Sonic construction
Old 12-19-2008 | 02:11 PM
bigboat28's Avatar
Default Sonic construction
Were the early 90's Sonic 30SS built with the same construction methods as the later 90's? I was told that they used a grid system without wood is that true? What are the stringers made of in the early 90's and the later 90's? Is the transom the only wood used?
bigboat28 is offline
Old 12-19-2008 | 06:33 PM
GO4BROKE's Avatar
They have always used wood stringers, balsa coring. 3 piece construction hull, deck, cabin liner all glassed together. You will only find seams glassed together on very high end boats. Even Formula and Donzi don't. Very solid boats. They switched to the infusion process in 2003. Before that I think is was all pretty much the same.
[img][/img]
GO4BROKE is offline
Old 12-19-2008 | 10:36 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
45sonic/Bill will be the best one to answer this for you.
Sydwayz is offline
bigboat28
Sonic
3
09-16-2008 10:04 AM
myturn
Sonic
5
11-28-2005 08:02 PM
97BossHammer
04-16-2004 07:57 PM
JimmyBaja
Baja
68
03-16-2004 11:16 PM
Greg Mc
2
05-29-2003 09:27 PM
