low water pickup >
low water pickup
low water pickup
Old 12-19-2008 | 06:18 PM
Default low water pickup
Im looking at installing a low water pickup to feed my intercooler only, for my supercharger install. Im going to use the drive pickup to cool the motor as it is from the factory. Is there any tips or tricks for install? Does anybody have any pics of there install?
conquest30' is offline
Old 12-24-2008 | 06:01 PM
HotPursuit's Avatar
I would use the drive for the cooler and the low water for the engine.
HotPursuit is offline
Old 12-24-2008 | 06:08 PM
HotPursuit's Avatar
Here ya go,, if you do the install make sure you check and check again to make sure the lay out is right!!! Measure 5 times cut once cause once you drill a hole in the bottom theres no turning back.
Attached Thumbnails low water pickup-img_0520.jpg   low water pickup-img_0519.jpg
Old 12-24-2008 | 07:33 PM
CB-BLR's Avatar
Chris
Don't they make adjustable depth pickups?
Or was notching the bottom of the hull intentional?
I believe that Dustin Whipple recommends using the external pickup for the innercooler, because water over-pressuriization is not an issue due to the exit side of the innercooler being dumped over-board.
Chris
CB-BLR is offline
Old 12-25-2008 | 10:51 AM
yeah dustin said use the low pickup for the intercooler because when your idling theres no water going through the intercooler which is good cause you dont want it to be to rich and load up if it was routed through the drive
Old 12-27-2008 | 08:59 PM
HotPursuit's Avatar
Chris
The low water is adjustable but you have alot more drag if the pickup is below the bottom.I recommended running the low water for the engine because of the increased water flow.But did forget on a bravo setup it's pumping water all the time from the drive.You dont want water running through the intercooler when your idling..
lennyk
07-15-2008 07:19 PM
GregP
4
06-13-2007 03:50 PM
SSComp
1
12-25-2005 10:40 AM
kilroy
07-21-2004 08:34 AM
kilroy
2
07-19-2004 02:00 PM
