Mercury extended warranty on 525's, worth it? >
Old 12-22-2008 | 03:48 PM
Default Mercury extended warranty on 525's, worth it?
My buddy has a pair of 525's running out of warranty shortly. 235 hours with only a Map(p) sensor failing. Is the 5 year extended warranty worth the cost?
I know it works out on the black motors but the blue motors I thought had 5 year claim limits (like $15,000 in claims in the 5 years). The black motors do not have claim limits with the exception of time.
Jupiter Sunsation is offline
Old 12-22-2008 | 04:15 PM
the waranty does not cover wear and tear , only defect's . and with 235 hour's on them i would asume they will need a rebuild soon . and that is not a waranty claim
mike
mikebrls is offline
Old 12-22-2008 | 05:01 PM
lucky strike's Avatar
Can you buy a extended warranty on a 525 with those hrs ?
If you can how much is it ?
lucky strike is offline
Old 12-22-2008 | 05:17 PM
Yes because it is still under the factory 1 yr. warranty. Don't know the price but I will tommorow.
Old 12-22-2008 | 05:20 PM
BAJA WILL's Avatar
Registered User
Rebuild at 235 Hours Not unless he's been running the holy chit out of them. Time to replace valve springs and leak down, compression test. I see blue motors if well taken care of go to 800 hours before needing a rebuild. But everyone need to make their own decisions.
WILL
BAJA WILL is offline
Old 12-22-2008 | 05:57 PM
LostinBoston's Avatar
I bought the extended warranty. It pays to do it for the drives. I had a faulty cone clutch, that was bandaided too many times until finally fixed correctly under the extended warranty. My CMI headers leaked and took out an engine with the warranty DID NOT cover though so i dnt think its worth it for the engines alone, but probaly for the drives. The best option though if buying new to buy something without merc engines/drives.
LostinBoston is offline
Old 12-22-2008 | 05:59 PM
WILL
Exactly what I was thinking...235hrs is not alot on N/A motors, they are made to last 500-750 if maintained properly.....and some guys get 800-900hrs.
spilman is offline
Old 12-22-2008 | 07:33 PM
BAJA WILL's Avatar
Registered User
We got a guy on the lake who has 900 hours on a HP500, but he has replaced the springs and lifters 3 times. He jokes with us that he will replace the bearings at 1000
WILL
Old 12-22-2008 | 07:54 PM
H2Xmark's Avatar
if it dont cover the headers and wear and tear i would just save my money
H2Xmark is offline
Old 12-22-2008 | 08:09 PM
this is what i was saying " to sum it up "
mikebrls is offline
