140 in older Daytona 33?
Registered User
Dyno at 1020hp and 1050lbs of torque, drives were xr bravo at 1.25, merc 36" props or labbed 34" (both 4 blade). Ran the boat with 2" imco shorties but performed the best at standard drives with 36's. The acceleration on this boat was unreal. The 33 I owned was a single step bottom which was achallenge in itself. The person you need to talk to is on this forum under khadley very good with the set up on these 33's (power,drives and etc.). This is the same boat that fastboats has for sale in florida.
she ran 112.8 out of the box with 500 hps,
Wow! I'm surprised you needed that much heat to see 140mph
Scott 128 mph was the best with 1000s and Imco sc drives , and after Eliminator in Mira loma rolled her over and redid the bottum and added the inserts
did you get the tab on yet ????????????????????//
FYI Runnin hot new 33's dont have an air tab nor do they need one. Noticed that you love to bash Eliminator as much as possible. no popoise 139mph 700 mercs. not saying there wasnt a porpoise problem to begin with but the hulls have changed since you had your issue.
new 33's dont have an air tab nor do they need one. 139mph 700 mercs. [/QUOTE]
What gear ratio and props are you running?
do you have a new 33 w/ 700 mercs?
sounds like a good mph for that package.
