Whipple or Pro Charger ?
Was going to buy a Whipple charger then did some more research and I have almost decided to change and get a Pro Charger. The Pros;The ;Pro Charger is half the cost, also a 3yr. Warranty vs. 1yr. and the Pro Charger is making more power at a lower rpm (765hp @5200rpm w/m-3sc @5lbs.). Overall I feel the Pro Charger is running much more efficient due to the large cooler. They claim that the reason they do not need to change the ecu is that they do not need to retard the timing because the intake charge is so cool (more than 3 times the cooling cap.). Pro Charger also claims that Whipple is retarding the timing because the intake charge is hotter and is needed for detination. Whipple is also taking thier HP reading at 5700 vs. Pro Charger at 5200. Why should I spin the engine excessivly to get the same HP?
I have a 02 29' Fountain fever single Hp500efi and because of the space available to me I feel that the Pro Charger is my best choice ; am I missing the boat ? I do not mind spending the extra money for the Whipple but do not want to if I do not need to .Yea the Whipple looks cooler...... Experts please help me make a decision. M-3SC vs. Whipple stage 1
Thanks , Chris
Thanks , Chris
Whipple does a much better job on EFI motors managing the fuel in my opinion.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
I bought my boat with twin 500EFI Procharged motors....M3SC at 8 PSI. They were reported to make 830hp, I talked to a shop that had set up a number of them on a dyno and claimed they would see about 790 out of that set-up....no way 5 PSI is making over 700 hp.
If you really spend the money to set each one up properly both should be reliable......this means putting the motor on a dyno and having it tuned properly....I also believe that the Procharger setup will take them longer to set up correctly.
If you just bolt this stuf on and run it.....chances are the Procharger will grenade you motor twice as fast as the Whipple (might take a few years, but will hapen faster)
The procharger is a more efficient blower in and of itself. Also, since the blower, intercooler, and intake manifold isn't all stuffed in on the top of the V, the intake and intercooler can also be much more efficient. The end result will be that the procharger will make more power with less boost. The compressor itself will also be more durable.
Having said that, the procharger will also not make boost as low in the rpm band. I would also hesitate to run ANY blower configuration without a recal. Any change of that magnitude really does need it. yes, it may run and make power without recaling, but it will not be optimum for power, fuel econ or engine life.
I think "some" people still run whipples and roots type blowers because they look a lot cooler. If you don't need the low end torque (the procharger will catch up around 4000rpm), and don't care that you blower looks like an A/C compressor, the procharger is the way to go
If you are limited to using a centrifical supercharger I would highly recomend the Vortech supercharger system. I have one on my 502mpi for about 100 hrs now and it has been very dependable and turnkey with no issues. I would be surprised if any system could be used without some type of ECU remaping.[/I]
WHIPPLE!! Even though the procharger looks cheaper at first it will end up costing the same or more then a Whipple by the time you have it all set up, installed properly and tuned. I like prochargers and Vortech and have seen them make awesome reliable power, but there is not a more comprehensive kit then the whipple. Look at motors from Teague, Eddie Young, Merc racing.. etc. Those guys are all using screws for a reason..
Contact Mark at percision marine He did a procharger for me and he also dyno it 8lbs boast made 820 hp great EFI motor he also does whiple he also will give ayou a deal on eighter one.
http://pmefi.com/
http://pmefi.com/
What these guys are saying is true. It is all in the setup. You can make great power with both. On entry level stuff you can do it cheaper with a procharger. The out of the box whipple stuff is better though. If you are building an expensive engine the price difference is not that much in the end.
