2003 8.1 Mercruiser Horizon (No Fire 2,4,6,8) >
Old 12-29-2008 | 01:35 PM
Default 2003 8.1 Mercruiser Horizon (No Fire 2,4,6,8)
I need some help, I have a 2003 8.1 Mercruiser Horizon engine that has no fire to the plugs on the even bank 2,4,6,8 there is fire on the odd bank 1,3,5,7 Not sure what to check on this matter.
hemihydro is offline
Old 12-31-2008 | 11:20 AM
Wink Scan It!
Sounds like your 496 Horizon is either in the Guardian "mode" with a trouble code or you could have a problem with the harness or connections on that side of the engine. You should be connecting a scan tool to the engine to isolate your problem here, anything else is an expensive and time consuming guessing exercise.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 12-31-2008 | 02:05 PM
I figured it could be a coil or the ECM. The codes just show gardian mode and knock sensor
Old 12-31-2008 | 03:02 PM
Fenderjack's Avatar
Pirate of the Chesapeake
I doubt that 4 coil packs went out at once, It is in a security mode, more then likely
John jr
Fenderjack is offline
Old 01-01-2009 | 01:20 PM
Michigan Mad Man
Check the plug that connects the 4 coils on that side of the engine. I have seen them get disconnected.
TylerCrockett is offline
Old 01-01-2009 | 08:49 PM
I 2nd that, check the harness, also make sure the wires haven't pushed out the back of the plugs, it will be connected but the wires can be pushed out enough not to make a connection.
Then check all of the grounds, make sure they are not loose or broken (even the small wires).
That is where I would start.
26 Spyder is offline
Cevert
03-15-2014 01:27 PM
megstoytoo
6
12-15-2006 10:26 PM
boomer
07-20-2005 02:50 PM
LETSROLL
05-02-2005 07:38 PM
LIOPA
05-29-2003 01:30 PM
