496 upgrade
Old 01-04-2009 | 01:56 PM
Default 496 upgrade
Looking to upgrade a 496 mag to 496 ho . what all will have to be changed ? And what about the computer ? thanks for any help Jeff
Jeff P31 is offline
Old 01-04-2009 | 02:20 PM
How much are you ready to spend? I myself that it is worth the money just to pick up 30 hp. If you are going to upgrade spend the money and you can go to 700hp for about 10-15 grand. Just my opinion.
indywhsle is offline
Old 01-04-2009 | 03:17 PM
GO4BROKE's Avatar
I think its just a cam and computer upgrade.
[img][/img]
GO4BROKE is offline
Old 01-05-2009 | 08:05 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
There are several different upgrades. Some are better than others for the money. The 2 biggest & best power makers are the Raylar kits & the whipple kits. They are also the most money. However there are lesser costly things that can also be done to increase perf & power, but again some are better than others there.. We have done quite a bit of work with 496s. It would be more helpful if you could let us know what kind of power you seek & ammount you are looking to spend.. Then we can let you know what would give you the most for your $$ Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 01-05-2009 | 10:16 AM
I too think it is just a cam difference between a 496 mag and 496 HO. Also in some of the older models the Ho had forged internals.
Baja_man is offline
Old 01-05-2009 | 10:30 AM
Some of the 496's did have forged parts. Also the main difference between the mag & mag Ho is the mag Ho has a different cam AND ecm program. Jamie / Lakeside
Old 01-05-2009 | 12:29 PM
You would be $$$ and HP ahead to go with a Raylar Kit.
Griff is offline
Old 01-05-2009 | 04:37 PM
We inquired a 496 mag from a wreck ,and have it apart . And thought while it was apart that if it was just a cam change and a computer fix for the extra hp we would change them . we are not looking to put a raylar kit in it . One 750 x 2 hp boat is lots . thanks again for the help Jeff
Jeff P31 is offline
Old 01-06-2009 | 06:42 AM
Michigan Mad Man
It is a camshaft and a ecu program. I might have a used take out cam.
TylerCrockett is offline
Old 01-06-2009 | 09:02 AM
Can the current ecu be reprogramed or do i need to get a new one ? If so how much ? thanks again Jeff
Jeff P31 is offline
