What do my engines weigh? >
Old 01-08-2009 | 06:33 PM
JasonSmith's Avatar
Default What do my engines weigh?
454 Mag Mpi's with aluminum heads, side mount Whipples & Dana exhaust.
How much do you suppose they weigh?
JasonSmith is offline
Old 01-08-2009 | 07:18 PM
you have any pics of your side mount whipple cause im in the process of installing one, and i heard the have problems? Also im guessing u have MEFI-1 and VST fuel system? did u leave it or upgrade> sorry for all the questions
conquest30' is offline
Old 01-08-2009 | 07:25 PM
JasonSmith's Avatar
I had the cool fuel setup. MEFI3 setup.
I took all that off, went with a 2 bar map sensor, SX fuel pumps & regulator & custom tune.
Pics:
http://www.putfile.com/pic/5516513
http://www.putfile.com/pic/5516508
http://www.putfile.com/pic/5516509
Old 01-09-2009 | 04:29 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Jason I know you dont have a 525, but if you were to use it as a reference point for a BBC: as per Mercury's site the 525 weights about 1200 lbs, I would guess that the Dana's weigh about the same as the CMI since you dont have cast iron. Then you would need to add the weihgt for your blower kit say apx 100lbs.. Hope this helps.. Jamie / Lakeside
Merc 525 specs
On a different note, what are you up to now. Between the carbon fiber questions & now this. You sparked my curiosity as to what you are working on now.
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
JasonSmith
9
02-26-2006 05:35 PM
24degrees
3
11-13-2005 03:06 PM
sommerfliesby
Fountain
1
04-23-2005 12:12 PM
Shah Mat
1
02-02-2005 07:05 PM
