1993 Suburban Heat problem -Help!
hey guys, I know many of you are very handy so maybe you can help me out. The front heat in my suburban stopped working the other day. The rear heat works fine. The lights on the control panel work, but the digital part that shows what heat settings are do not. And it cannot be adjusted, the heat will not turn on. I brought it the mechanic and he reset something, and it worked for a few days, but then died again. Anyone know what he reset? or if it is something I can do myself.
Thanks in advance for all your knowledge!
Jon
Jon
Jon
Jon
Some others may have ideas that can help you as well.. But thats what comes to mind at the moment..
Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Look up blower resistor on sites like dieselplace.com or fullsizechevy.com A known issue with them. There is also two fuses associated with this system AND the connectors are prone to melting. Nice, eh?
No joke I literally just got back from autozone buying the same item. For my '97 Dually its part number DR776 $17 and I would replace the blower if its old too PM149 $48. Again these part #s are for a '97 K3500 so you will want to verify. Let me know how it goes.
thanks guys, I had it in the shop today and we pulled the dash, disconnected it, then reconnected it. worked for about ten minutes. I think there is a short somewhere in the dash because the radio also cut out when he moved the thing like two wires touched. I know the truck is ancient, it was supposed to be gone, but our dog had some major surgery and spent a month in the emergency vet. so unfortunately the money for a new suburban is not available right now. thanks for the anwers, I will take a look into both your suggestions tomorrow.
BajaRunner
14
12-30-2004 09:45 AM
