New Throttlebody for 500 and 525 >
Old 01-19-2009 | 10:21 PM
Michigan Mad Man
Default New Throttlebody for 500 and 525
This is the new throttlebody we made and tested for the 500 and 525 engine. The engine in the video is a 500 Mercury with 250 hours. We put a set of Dart 310 heads right out of the box No Porting and a Crane 741 cam. We made 575 HP with the stock throttlebody. We then installed the new throttlebody and made 605 HP. The new throttlebody flows about 2000cfm. We made a iac adapter to mount on the front block off plate but the adapter will bolt right on the back of a 525 manifold. It also gained 30 ft #'s of torque thru out the rpm range. http://www.youtube.com/watch?v=kT8FmzMo2Uw
TylerCrockett is offline
Old 01-19-2009 | 10:23 PM
BAJA WILL's Avatar
Registered User
Nice, now that is some bolt on performance.
BAJA WILL is offline
Old 01-19-2009 | 10:37 PM
525 gains?
dreamer is offline
Old 01-20-2009 | 09:28 AM
500 gains with out the heads and cam? will it give a 30 hp diff on a stock motor?
dreamer is offline
Old 01-20-2009 | 10:07 AM
Dock Holiday's Avatar
Charter Member #34
Tyler that is awesome and a great package that I had good experience with on the 500's.
The throttle body really looks strange I guess that is called "Thinking Out Of The Box".
Nice job and it's nice to see folks developing products that really work.
Good luck
Dock Holiday is offline
Old 01-20-2009 | 04:06 PM
Looks interesting--how much extra height is required over a stock 525?
suntimes is offline
Old 01-20-2009 | 04:25 PM
Good job Tyler! Now make one with four holes over the whole plenum.
tomcat is offline
Old 01-20-2009 | 06:25 PM
Wahoo ATV's Avatar
Racer
It added 30 hp and 30 torque to my stock 525.
Wahoo ATV is offline
Old 01-20-2009 | 06:45 PM
How much? I need 2.
Velocity Tom is offline
Old 01-21-2009 | 06:24 AM
Michigan Mad Man
We gained 22HP on a stock engine. It really helps when you got full ported heads and a bigger cam when you can't move enough air thru the front of the manifold.
