proper way to put boat back in the water after its winterized >
Old 01-25-2009 | 08:48 AM
chadman99's Avatar
Default proper way to put boat back in the water after its winterized
i have a 91 fourmula 242ls with a 502 in just wondering how others get their boats seaworthy after its been winterized?
chadman99 is offline
Old 01-25-2009 | 08:59 AM
Conect all the hoses back,,,check everything, Then warm up the engine on the waterhose.
Change oil ,check drivefluid,check sparkplugs, change fuel filter.
Spray all electric stuff with WD 40,,clean the boat ,wax or polish it and go have fun.
Depends on what drive u have ,also check the gimbal bearing and the belows.
On the hose when u warm up ,make shure u check the waterlines for leaks( exhaust and sofort)
Thats what i would do.
DareDevil is offline
Old 01-25-2009 | 08:01 PM
I put it in the water and turn the key
You really shouldn't have to do anything special, but that can vary a little depending on who winterized it and if they disconnected some hoses. Charge the batteries and check all fluid levels. Check for leaks or water in bilge after you put it in the water and start it.
Griff is offline
Velocity Vector
11-11-2008 08:48 PM
fountainguy214
03-22-2008 07:23 AM
b-rad
17
01-18-2008 11:01 AM
BajaFresh
12-17-2007 01:39 PM
Audiofn
05-24-2004 03:14 PM
