alpha 1 leg shower >
alpha 1 leg shower
alpha 1 leg shower
Old 01-29-2009 | 08:41 AM
Default alpha 1 leg shower
Just need to know if there is any benefit in fitting a leg shower to alpha 1 pushed by 300 hp sb chev?
A guru told me not to bother as merc legs water jacketed all the way.
I hope someone can give me the lowdown on this.
cheers
bustedarse is offline
Old 01-29-2009 | 07:12 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default shower
Sure it helps keep down the heat on the top gear case. There is no water around it when the boat is running foward at any speed faster than a idle.
Fenderjack is offline
Old 01-30-2009 | 07:19 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
I run them on all of my boats. I also ran them on the alphas that I have had. It is cheap insurance & they do work. Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 01-30-2009 | 07:26 AM
Thanks guys.
That does it for me.
I will install one for sure
Cheers
Old 01-30-2009 | 11:17 AM
spazboz's Avatar
I forget who makes it, but they make a drive shower for the Alpha's that doesn't require drilling holes for the tubes anymore. It just bolts onto the Anchor pin for the trim cylinders.
spazboz is offline
Old 01-30-2009 | 06:31 PM
That sounds like the ideal setup.
I will try to find who produces this style.
If anyone knows what brand it is could they please post.
Information is as always , appreciated
Cheers
Old 01-31-2009 | 01:30 PM
spazboz's Avatar
Thumbs up Here ya go.
http://www.briterinnovations.com/bri...ve-showers.asp
This is what you are looking for. We put these on all our boats now and it works great. My friend used to have a 21 foot Scarab that would chalk-up REAL bad on the upper gear-case. After the drive shower install it doesn't chalk-up at all.
spazboz is offline
Old 01-31-2009 | 05:57 PM
That looks just the ticket.
Im surprised that all of them dont mount that way
Cheers
Old 02-01-2009 | 10:19 AM
I have those same ones on my Bravo 1 drives, and the drives don't get chalky any more and I noticed no lost of speed or cavitation problems.
johnny b good is offline
Old 02-01-2009 | 11:03 AM
28Eliminator's Avatar
I would defenitely put one on. I have seen several alphas granaid the uppers, just like the bravo's. In fact I let one loose years ago, at a really bad time. Always had chalk film on it also. I have read that the alphas build more heat than the bravo's. I never run without one since that.
28Eliminator is offline
