Hey Outlaw Boys >
Hey Outlaw Boys
Hey Outlaw Boys
Old 03-16-2002 | 06:39 PM
Default Hey Outlaw Boys
Have any of you Outlaw boys removed your plexiglass faring? Mine had 2 areas in it where the white paint on the inside had scratched away. I pulled it off in order to re-paint those areas from the reverse side.
Man – it was nasty behind that faring when I pulled it off. It’s no wonder that I had those scratches. It looked like the guy at the factory did not clean the area very well. There were fiberglass splinters still behind the faring from when the mounting holes were drilled. It’s no mystery where those scratches came from. I re-painted it white from the inside, cleaned away all the crud, and re-installed it with those little white plastic screw-head covers. Looks great.
29 OUTLAW is offline
Old 03-16-2002 | 07:11 PM
garshev's Avatar
Lightbulb outlaw windscreens
I was wondering how you prepped it and what kind of paint you used because mine is doing the same. Did you sand the plexi to rmove the bad spots? etc.
garshev is offline
Old 03-16-2002 | 07:49 PM
The only prep I did was to clean the area and remove any flaking. I just used regular spray paint. Afterall, this is inside out painting so just filling in the blank spots seemed to be good enough.
Perhaps Chris did more.
388Hustler
04-15-2004 08:53 AM
ScottB
General Racing Discussion
8
05-09-2003 09:53 AM
RiverGirl
10-31-2002 08:17 AM
otis311
Baja
11
05-29-2002 09:22 AM
29 OUTLAW
Baja
3
03-25-2002 02:11 PM
