first time addjustment >
Old 02-16-2009 | 08:42 AM
Ken N's Avatar
Arrow first time addjustment
When installing a new set off hydraulile roller lifter,pushrods, and roller rockers (they have not been pump up) For the first time do you turn down onr turn or 1/4 turn 1999 BBC.
Ken N is offline
Old 02-16-2009 | 09:35 AM
hoozeyurdaddy's Avatar
once you've got all the slop out of the pushrods, I will go 3/4 to 1 turn, did they give you any instructions for the lifters.
hoozeyurdaddy is offline
Old 02-16-2009 | 11:46 AM
http://www.cranecams.com/?show=techarticle&id=2
3/4 of a turn will get you about .040 preload.
Griff is offline
Old 02-16-2009 | 12:28 PM
Ken N's Avatar
Arrow lifters
No instructions with the lifters, but they are Model
Ken N is offline
Old 02-16-2009 | 01:44 PM
Morel??????
Griff is offline
Old 02-16-2009 | 04:18 PM
This tells the whole story !!!!!!!
Jeff P31 is offline
Old 02-18-2009 | 04:58 PM
bb
Jeff P31 is offline
Old 02-19-2009 | 07:01 AM
Michigan Mad Man
Take a squirt oil can and fill them thru the small hole in the side of the lifter before you put them in. Install them and set 3/4 turn preload. We put a little extreme pressure lube on the pushrod tips. I also spray the valve springs and rockers with the Comp Cam assembly spray.
TylerCrockett is offline
Old 02-19-2009 | 08:52 AM
Ken N's Avatar
Arrow lifters
Tyler Crockett
Would priming the engine through the distribor hole with a electric drill do the same thing. The engine has been sitting all winter anyways?
Ken N.
Ken N is offline
Hauling Trash
OPA/The Jersey Boyz
4
01-22-2007 04:35 PM
off roading
12-16-2006 10:20 PM
HayJay
06-01-2006 07:00 PM
TeamRelentless
General Racing Discussion
2
03-08-2004 03:41 PM
