357 SR-1: 3 or 4 blade prop? >
Old 02-16-2009 | 12:39 PM
Default 357 SR-1: 3 or 4 blade prop?
I'm running Merc 4 blade props on my 357 SR-1. Guy I bought it from said it runs much better w/ the 4 blade than it did with a 3 blade. I'm rebuilding my 502 mpi's to about 500 h.p. and so will need to go up in pitch. I'm wondering if I should be thinking about a 3 blade or stick with a 4? Any recommendations appreciated-
ctuck0659 is offline
Old 02-16-2009 | 11:16 PM
jeff32's Avatar
spinning mirage 21 3 blades on mine...
jeff32 is offline
Old 02-17-2009 | 10:38 AM
What kind of speeds are you guys doing with these boats,and rotation on your props in or out.
markku4444 is offline
Old 02-17-2009 | 10:56 AM
I was barely breaking 60 w/ 502's/ 415 hp (21P 4- blade props.) Don't know what the rebuilds to 500 hp will yield. Props rotate out, if I recall correctly-
Old 02-17-2009 | 05:04 PM
jeff32's Avatar
tweaked up 454-420 at 480hp = 63-64 gps at 5400 rpm...
jeff32 is offline
Old 02-18-2009 | 09:37 PM
Full Force's Avatar
I am assuming still a TRS boat, with 500 hp and that boat I am going to say 23P Mirage Plus's, the TRS are deep and will do betetr with 3 blades, cruise will be better with 4 blades, not top end. even with 500 hp I am going to bet 65 MPH max.
Full Force is offline
Old 02-19-2009 | 08:27 AM
Yes, it's a TRS. I'll start w/ 23P Mirage then and go from there. By the way, what's the difference between Mirage and Mirage plus?
Old 02-19-2009 | 03:27 PM
Full Force's Avatar
Dfference is that the plus has more cup to help bring that big bow up, I run 23P Mirage on mine, bow stays down no matter how I trim it, I am going to a plus in the spring, I was turning 5100 at 65MPH
Inspector
Prop Talk
1
07-09-2007 07:50 AM
offshoreratboy
Prop Talk
11
06-27-2007 09:04 AM
Rebel_Heart
Prop Talk
16
03-23-2006 01:29 PM
CA_Southpaw
American Offshore
13
11-06-2005 07:18 PM
NetGain
19
06-29-2004 08:32 PM
