setting up valvetrain >
Old 02-18-2009 | 04:38 PM
Default setting up valvetrain
i have all my parts in. i just installed my heads. i have hydraulic roller lifters, the correct pushrods, and roller rockers. the engine has not been primed and the lifters have not been pumped up. i have conflicting tips from people. one person said i should tighten the rocker arm till 0 lash then crank it one half turn.. then someone else said i have to adjust it warm.
Fixxxer22 is offline
Old 02-18-2009 | 05:15 PM
Try reading this good luck.
http://www.cranecams.com/?show=techarticle&id=2
Jeff P31 is offline
Old 02-18-2009 | 06:37 PM
Good article, and exactly how I have done it for decades
I would suggest checking your pushrod length also.
And last degree in the cam, if you haven't.
Good luck with your build.
1BIGJIM is offline
Old 02-18-2009 | 06:40 PM
Originally Posted by Jeff P31
thank you so much that article helped alot. just what i needed. you know when you are assemebling this stuff you can loose sleep if you are not 100% sure of yourself.
KEPP
New Products and Member Discounts
3
11-19-2008 11:14 AM
BadDog
18
05-29-2007 01:11 PM
zimm17
9
04-14-2006 06:07 PM
duster340
1
08-16-2002 07:33 PM
