now my valve covers wont fit!!!!! >
Old 02-19-2009 | 09:57 AM
Default now my valve covers wont fit!!!!!
i am in the process of getting my 502 back together i added roller rockers. anyways the factory valve covers will no longer fit. i am running gil/ mercruiser performance manifolds. i called my speed shop to pick up a set of tall valve covers and they said my exhaust wont clear the larger covers. what do i do?
Fixxxer22 is offline
Old 02-19-2009 | 10:09 AM
110351568526 on ebay.... look like they have more clearance... but will they fit bbc gen V. this stuff keeps adding up. its killing me.
Old 02-19-2009 | 10:14 AM
PatriYacht's Avatar
Try heavy cork gaskets from Mr Gasket or Fel Pro. They come in several thicknesses. Get you another 1/8 inch at least. Jegs or Summit Racing.
PatriYacht is offline
Old 02-19-2009 | 11:07 AM
Merc grinds the corners off a couple of the roller rockers used on the HP motors. Looks kind of crude, considering what they charge for motors.
Might want to look for a picture of real Merc HP motors and see if that is your problem.
sun28int1995 is offline
Old 02-19-2009 | 11:21 AM
i think they even had different covers than i did. every locknut hits.... what about those 420 merc valve covers.
Old 02-19-2009 | 11:25 AM
You need to grind off the drip tabs on the inside of the valve covers. You may also need to grind off the corners of the roller rocker arms on a couple to clear the baffles at the fill holes. They will fit.
Griff is offline
Old 02-19-2009 | 11:38 AM
DORaymond's Avatar
You may also need to break off the drip oilers that hang down from the top underside of the covers. You can snap them off with pliers.
DORaymond is offline
Old 02-19-2009 | 11:54 AM
No body said it was going to be easy or cheap !!!!!! Keep smiling and think of all the fun you are going to have when it's all back together.
Jeff P31 is offline
Old 02-19-2009 | 12:40 PM
All the roller rockers I have bought in the past had two in the set that had the corners rounded off. I did not want to mess with grinding tabs off. I gound off one tab to see if it would work, and it would but I still would need to use two gaskets.
I just purchased new valve covers.
1BIGJIM is offline
Old 02-19-2009 | 01:15 PM
PatriYacht's Avatar
Every set of Crane gold rockers I have ever seen in a bb Chevy had those 2 clearenced rockers. Not a big deal. Only takes a little work on a belt sander. Most are cleared more than they have to be. 420 valve covers will fit.They came with Crane rockers from Merc. But you still have to grind the corners on 2 rockers.
