Thinking of buying this engine.. 454 510hp opinions....... >
Old 02-23-2009 | 04:45 PM
Cool Thinking of buying this engine.. 454 510hp opinions.......
I have been searching for a good rebuilt engine that produces 500 plus hp.. this engine comes with a one year warranty from an engine builder in toronto.
Can anyone tell me if they think it is worth whyle...
Thanks in advance
454 chev 510hp
this engine is complete intake to oil pan, dyno tested at 502 hp @5900 with the
max torque at 4500 542 fl/lbs......
the engine includes a cast crank that has been magnafluxed, forged pistons, moly rings
elebrock rpm air gap intake , roller tip rockers, double roller timing kit, hd oil pump
marine hd gaskets, 3 angle valve job, premium engine bearings, balanced assembly
3600.00 with my core.. Canadian dollars
Outlaw00024 is offline
Old 02-23-2009 | 04:48 PM
Thanks in advance
454 chev 510hp
Sounds like a good price but I don't know if I woud trust that crank at 6000 rpms. With a 1 year warranty, you can afford to break it though. Just don't know if you want to bet the season.
Is the cam set up for your exhaust? If it is making that much power, I am thinking it is a pretty agressive cam.
jeff1000man is offline
Old 02-23-2009 | 05:12 PM
Registered User
Is the warranty valid in a marine application? I bet not . I am not sure I would want to turn those RPM's with a cast crank for extended periods of time. Price is definately right though.
320es is offline
Old 02-23-2009 | 05:30 PM
Yes the warranty is valid for the marine app... But.. I just recieved a call on a 502 re done last season a 500 hp with low hours... actually just as I finished posting, he wants 6k less my trade..
I am pretty undecided.. sell my boat to upgrade to larger. boats are cheep but will i sell mine? thats the question.
I dont think I want to get into a cast crank scenario reving at 6000 rpms... melt down after an hour for sure...
I will find out about the 502 on thursday.. keep my fingers crossed... paint it up and add some stainless. drop it in and go
Old 02-23-2009 | 05:36 PM
It won't melt down, it will break.
I had one that I spun at 6000 all season on a 2 bolt motor, but I knew that it could come apart at any time. Others have not had the same luck.
In your case, since you are bargain shopping, I would suggest spending a little more for a better rig.
Old 02-23-2009 | 05:51 PM
Have pretty much come to the same conclusion...
Bargain shoppin I am..lol
Will find out about the 502 thursday...
Old 02-23-2009 | 05:58 PM
I still have this one if you get interested. 475+- Hp at 53-5500 rpms.
Forged internals. Studded 2 bolt block. With carb and ignitio included and remote and cooler.
You need you accesories, senders, wiring etc.
No warranty, but it only has 14 hours on the rotating assembly and a fresh valve job.
You do have to run premium and use a tube header exhaust.
$4k plus freight. No trade in needed. Time to get it out of my shop.
Oh it is a solid lift cam also.
Attached Thumbnails Thinking of buying this engine.. 454 510hp opinions.......-000_1611.jpg   Thinking of buying this engine.. 454 510hp opinions.......-000_1610.jpg   Thinking of buying this engine.. 454 510hp opinions.......-000_1613.jpg
Old 02-23-2009 | 06:15 PM
Jeff1000, where is your shop, how can I get in touch with you.Wildhorses
wildhorses is offline
Old 02-23-2009 | 06:29 PM
Thanks in advance
454 chev 510hp
What is the max in your budget ?? I have a 540 making 650hp low hours ..built by Hewitts in brockville ..all good stuff ..pm me if you want to discuss further ...also have XR..drives ..
whataride is offline
Old 02-23-2009 | 06:30 PM
PM sent and my shop is in Lake Conroe.
