Tying in a power steering cooler...
Probably going to
but I'm drawing a blank sitting here at work.
I'm switching from a dual cooler to seperate engine and power steering coolers with the water inlet/outlet drastically smaller than the engine cooler. Obviously if I tie them together flow is restricted to the smaller diameter. So what is the best way to plumb the water for the power steering cooler both inlet and outlet?
Anyone?
but I'm drawing a blank sitting here at work. I'm switching from a dual cooler to seperate engine and power steering coolers with the water inlet/outlet drastically smaller than the engine cooler. Obviously if I tie them together flow is restricted to the smaller diameter. So what is the best way to plumb the water for the power steering cooler both inlet and outlet?
Anyone?
I agree with parallel but what's the cleanest way to route the water input and output? I need to either have a seperate location or some sort of "tee". My concern was with backflow creating an issue.
I'm probably overthinking this but everything is apart and I had the combination cooler before.
I generally use seperate oil and p/s coolers, but I use a p/s cooler with the same fitting size as the oil cooler. I either use 1" npt or 1 1/4 slip on. I recommend getting a p/s cooler of the same size so there is no restriction to water flow or plumbing issues. In this case, I bring the water out of the pump, through the oil cooler, through the p/s cooler and then into the front of the engine. Hope this helps, Eddie.
If the cooler is copper you can cut and resolder new 1" npts fittings. I have done that and run them inline like Eddie recommended>>
