30' chris cat props >
30' chris cat props
30' chris cat props
Old 03-01-2009 | 10:42 PM
Registered User
Default 30' chris cat props
86 chris cat
30'
900SC (dynoed 900 HP @ 5.5 boost) moved 2' forward
#4 drives with merc. extension boxes (1.4 gears)
boat weights about 8000lbs
need help on props im hoping for about 130 mph my need to turn up the boost.
cody_white83 is offline
Old 03-02-2009 | 07:11 AM
Originally Posted by cody_white83
86 chris cat
30'
Cody,,,i forgot .....are they bigshaft #4's or smallshaft ?
Propwise i would start with a 4 blade 17-18 X 30-32 to see what she does.
DareDevil is offline
Old 03-10-2009 | 06:19 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
If you turn the engines at 6000, you'll need 36 inches of pitch. Test with 17"-17.5" diameter props in the largest pitch you can find. You need some type of base line to get started.
Brett
[email protected]
bbladesprops is offline
wannabe
Prop Talk
16
04-15-2009 05:57 PM
cody_white83
Prop Talk
0
03-01-2009 10:35 PM
mccaffertee
09-03-2008 09:54 AM
jmackin
Chris Craft
11
07-27-2008 09:21 AM
FOREVER YOUNG
Chris Craft
18
01-23-2008 11:30 AM
