353 Cabin Walls
The grey suede side walls down in my cabin have become rippled and started to hang down a little. Is there any kind of adhesive that you all would recommend to make that stick to the walls? Maybe some kind of "head-liner" adhesive?
It's likely the adhesive is STILL doing it's job. The problem is probably the foam backing coming apart and leaving 1/2 of itself stuck to the walls and letting the other 1/2 (which holds the part you see) fall. More adhesive is usually a temp. fix, complete replacement is usually necessary.
